Old 05-26-2019, 10:35 AM   #3
Anker
Worn cam chain tensioner pads. The brown bits are pieces off the pads.
If the chain gets loose enough it can skip a tooth. Try turning the engine manually and see if you can get the slots for the cam locking tool to line up. As far as I remember they should both be vertical at the same time. That should give you a clue.
1941 Dodge Luxury Liner Coupe
