Old 05-23-2019, 05:27 AM   #11
Starter986
1998 Boxster Silver/Red
Originally Posted by Geof3 View Post
Or, and it’s not quite as good but works, is drain your res, refill, start car wheels back and forth, drain refill, rinse/repeat etc. that will “freshen up” the fluid to some degree. The best replacement though is to get under the car... it’s not as bad as it seems. The mess on top of the engine from old, dead, puked up PS fluid is harder to clean, than replacing the fluid!
That's the route I considered, going into the reservoir. I'm going to do the same thing to my Edge as I believe it is my pump is making a slight groaning noise when in park and turning the steering wheel from left to right, and only about an inch each way. However, in the Edge I may just get under it and access the return line... and drain it.
The car makes zero noise... but I have no record if ever the PS fluid was changed.
Cheers!
1998 Porsche Boxster
