Thread: Radio question
Old 05-22-2019, 07:33 PM   #12
Burg Boxster
Originally Posted by gsy4771 View Post
I ended up with an Alpine headunit and amp. Can anyone recommend how/where I can run speaker wire from the frunk to inside the car?
Search on 'Rear Speaker Install' and you'll find a great spot where it's recommended to run rear speaker wires to a 6ch amp in the frunk (if applicable).
Posts will have pix. In a nutshell, remove battery and on firewall behind where battery is located look for a round or oval grommet. The grommet ends up being ~ 6" above accelerator pedal. Using a sharp exacto or utility knife cut a 1"x1" 'X' in middle of grommet. Feed a fish tape, dowel or other stiff wire from frunk side into passenger compartment. Use a flashlight to find said fish tape et al in corresponding location (it has to go thru insulation inside) in passenger compartment.
Good luck
"Cool Prius!"
- Nobody
