Old 05-21-2019, 06:16 AM   #1
Starter986
1998 Boxster Silver/Red
If you have time, I'd recommend checking the serpentine belt, hoses, change air filter, and maybe clean the throttle body and intake boots.
https://www.pelicanparts.com/techarticles/Boxster_Tech/28-FUEL-Throttle_Body_Cleaning_-_Boots/28-FUEL-Throttle_Body_Cleaning_-_Boots.htm
Also, I've read that the spark plug coils are prone to cracking. Maybe give them a look.
Good luck!
Same time I replaced the AOS I replaced the plugs/coils/WP/LTT and dropped the oil pan. That stuff is under the car... so I'm looking for "in there" while I'm on the top.
I will clean the throttle body and intake boots, as they do get a little oily.
Thanks for the recommendations. Cheers!
1998 Porsche Boxster
