Old 05-20-2019, 07:44 PM   #11
Zzorro
Zzorro's Avatar
Originally Posted by KCCO308 View Post
Replaced my discs with new slotted and drilled rotors and new pads. Also drained and changed the oil to set a baseline since I wasn't sure how long ago it was last changed since I bought. Bought an engine mount and serpentine belt to do as well but decided to hold off and do those with a new water pump and low temp thermostat so I can drain the cooling system to actually get to the motor mount a lot easier
Brakes look good. It's one of the upgrades I'm considering a little further down the road. I just did my engine mount. I did not need to take off my coolant lines. It all worked out great. But it you are replacing coolant anyways then it will just make the job easier.
Zzorro is offline   Reply With Quote
