Replaced my discs with new slotted and drilled rotors and new pads. Also drained and changed the oil to set a baseline since I wasn't sure how long ago it was last changed since I bought. Bought an engine mount and serpentine belt to do as well but decided to hold off and do those with a new water pump and low temp thermostat so I can drain the cooling system to actually get to the motor mount a lot easier.
