Originally Posted by Racer Boy
From the description you gave, it's likely the rear trailing arms, which although not fun to replace, are easy enough. You can do it with the car on ramps.
How many miles on the car?
the parts arent bad, about 150 each. Ive replaced mine on all my cars around 80K. trying to move them around doens't tell the story, everything looks fine but it isnt.
they are a challenge to replace unless you have a huge breaker bar, really helps to have the car on a lift. On ramps you have a tough time getting leverage and you cant swing the tool through the arc. You will need an alignment after as well.
I found it best to have a shop so this, but that's a personal decision.
