Old 05-18-2019, 09:06 AM   #4
tonythetiger
Will there be cake?
tonythetiger's Avatar
Share more detail in your process for cleaning the throttle body, it'll help the experts understand what could have gone wrong. Did you remove the TB from car? What method and products did you use? Anything unusual happen in the process?
FWIW, rough idle is often attributable to the MAF sensor. Either it was contaminated when you cleaned the throttle body or who knows. Try disconnecting the MAF for a change in symptoms.
