Old 05-17-2019, 12:06 PM   #1
sfkjeld
sfkjeld's Avatar
Heat shield?
Manual or Tip? If it's manual, when you're in 1st, obviously your clutch would be depressed. If that's the case, I'd also suspect the throwout bearing. Try pressing and releasing the clutch and see if the noise changes.
It is a manual. The clutch has no bearing so to speak, on the sound. Sounds exactly the same whether in gear, clutch in or out, or neutral. Thank you for the thought tho. I appreciate it. Cheers.
sfkjeld is online now   Reply With Quote
