Old 05-17-2019, 12:51 PM   #2
piper6909
piper6909's Avatar
Originally Posted by ZoomGlide125 View Post
I've have a 99 2.5 manual boxster that I've been fighting multiple gremlins with. I just got a new immobilizer/ecu/key from ecu Dr and now my locks seem to be working 90% better now. However after installing that new set the ignition will not turn off until I press the brake pedal. I can turn the key and take or out, but the engine will stay on until the brake pedal is touched. I replaced the ignition switch but the car still acts the same. I also can't find any information on this problem.
Any help or ideas on this?
I think your answer is inside your question: "...after installing that new set..."
If the problem started immediately after, I would suspect the Immobilizer or the ECU. Have you tried ECU Doctors for help?
What was wrong with your old Immobilizer/ECU?
