					Originally Posted by Topless  The fastest way to stretch rod bolts?  Downshift over rev.  Zing it past redline heel/toe with no load on the motor a few times   while entering a corner and rod bolts become stressed/stretched.
 Clogged oil passages is another possibility especially if someone was *liberal* with sealant when replacing the pan or adding a deep sump.  If that was the cause you could probably fish the oil passages and find it.  Another telltale sign is the oil pickup screen completely jammed with excess sealant.
Possibly guilty of the first situation but definitely guilty of the latter. Many orange snakes found in the pickup screen and one can assume that there were smaller pieces that squeaked by! Did I mention how stingy I was with a better sealant on the new install?
www.youtube.com/channel/UCohdrH2xHTklM1thxk0KKOQ? |
