Top mounts
During install of GT3 LCA:s I try to adress a Little more things while Iīm in there.. I see that the top mount on one side looks a bit fishy, so since I have time I will take it apart and have a look.
Since I put in adjustable LCA:s I donīt Think I need camber plates, but solid top mounts might be woth while.. Or what do you think? Any reasonable priced ones? Or is it even worth while to put in fresh OEM-mounts?
Would I even feel any difference with solid (spherical bearings) top mounts vs OEM on the track?
