Old 05-14-2019, 08:11 AM   #2
Lacostas
Originally Posted by beavis0076 View Post
heater core's seem to fail when the water pump does for some reason I don't yet understand. so if your water pump is now going bad, it could mean your heater core is as well. its easy to open up the area and see if there is antifreeze in the heater core box.
Hmm i doubt that the core heater fails too. Most probably its malfunctioning (rather than failing), until i fix the water pump ?
So, maybe when the WP is failing, the Core heater is not working as it should.
Lacostas is offline   Reply With Quote
