Originally Posted by YellowS2000
Front brake disc, pads change: Top caliper stud on each side of the car has decided to fuse themselves into the hub carrier to the extent it was nearly being the ratchet bar. Mechanic recons its not coming out without stripping the threads in the hub carrier....... grrrrrr
Going to order 2 new hub carriers from a breaker today.
Have your mechanic try welding a piece of metal bar to the caliper bolt, and use the metal bar's leverage to remove. Maybe a small sledge hammer to help it start turning a bit. Had the same situation and this worked for me. Save that hub carrier money and spend it on something nice on the car
2000 Boxster S, SPEC stage 1 clutch, Fabspeed sport headers, Fabspeed secondary cat deletes, Billy&Boat muffler, EVOM air intake, Ben006's Custom Short Shifter, Pedro's TechnoBrace, Eibach rear sway bar, De-snorkeled, Fred's custom projector HL
