Hi guys,
I have bought 2000 Boxster and I'm considering buying 16 inch OZ Ultraleggera to keep the weight down, but I would like to know will 318 mm front discs from Brembo and its calipers (dimension from Boxster S) will fit into 16 inch wheels or I have to go with 17 inch as on Boxster S?
Second question - in order to fit OZ Ultraleggera I need to fit wheel adapters, is this one ok?
https://www.ebay.com/itm/5x130-to-5x4-5-5x114-3-US-Wheel-Adapters-1-thick-14x1-5-studs-71-5-Bore-x-4/171952702245?hash=item28092e0325:g:WRsAAOSwb3laJDX ~
It has 14x1.5 and 71.5 mm bore which should be ok for Boxster. As they are 1 inch wide, will those wheel adapters do the same thing as 1 inch wide spacers?
Thank you,
Darjan
