Old 05-06-2019, 08:42 PM   #5
maytag
Who's askin'?
maytag's Avatar
Originally Posted by Evostumpy View Post
I just picked up a 99 Boxster and am trying to bring it back from the dead. It was last running in the fall. The car would start and run for about 3 seconds, and then not fire again until some hours later. I took a chance and replaced the Crank sensor (no tach movement when cranking). Then the car started for like 20 seconds with me feathering the gas and backfired and died. I looked under the car and there was a puddle of fuel under the passenger side from an exhaust junction. I checked fuel pressure and it was great, even after sitting for 30 min it still held. I took the throttle body T section off from between the intakes and there was fuel in both intakes and the T. My guess is some sort of vacuum issue that’s pulling fuel into the intakes? Any ideas? Thanks in advance!
Evostumpy, you've got two identical posts going on. Were I you, I'd kill one of these threads and focus on just the one.
