Start with the basics:
Replace spark plugs. Clean the TB. Check your air filter. CHANGE THE OIL IF YOU HAVEN'T ALREADY. (Old oil is bad oil, especially if you've been over-rich). Check your cam timing. Change the fuel filter.
My guesses would go;
stuck injectors.
Fouled plugs.
Air obstructions.
Really, hit your basic troubleshooting methods: fuel; check. Air: check. Spark; check. Timing; check. Then it runs.
