Old 05-06-2019, 01:28 PM   #11
BYprodriver
BYprodriver's Avatar
dremel... ? :-)
Thin cutoff wheel, when you buy the bolts make sure to get the same grade as the stock bolts & buy a couple nuts to fit the bolts. Thread a nut onto the bolt before you shorten the bolt, & then removing the nut restores the threads as you remove it.
