2.7 Porsche Boxster motor. $3900 shipped. The motor was taken out of a base boxster with 100,000 miles but at some point in it's life the motor was replaced with a factory Porsche replacement motor. You can tell it's a factory replacement motor because of the torque head bolts used throughout the whole motor. Only factory replacement motors use these type of bolts. Judging by the amount of dirt buildup, I'm guessing it has anywhere from 30,000-50,000 miles. This motor will work on 2003 and 2004 Base boxsters only. This motor was taken out of a non-wrecked boxster with an automatic transmission. This motor will work in a manual boxster but you'll have to transfer the manual wire harness and intake from the manual motor onto this motor. Sold with accessories in the pictures. The air conditioning compressor is not included. While this is a low mile motor, I highly suggest replacing the AOS, water pump, rear main seal, vacuum hoses and IMS while you have it out of the car. It ran great when in the car.
If you have a factory Porsche Child Seat, this piece is required to install the seat. Bolts to the seat frame, and accepts buckles from factory Porsche Child Seats. Professional installation required. Requires programming at your local Porsche dealer, only compatible with Porsche child seats with a seat belt with "belt tongue" connection. $100 shipped
