Type in w w w dot auto no space atlanta dot com/tinyresults.php?pn=99661320500;TB_iframe=true&height=550&width=875 to pull up a diagram showing the Very Unreasonably priced micro switch. I am sure Pelican (our host) could help you get one, as could any number of other vendors once supplied with the part number in the above link.
But given the cost and the uncertainty that your microswitch is really causing your problem, I would probably look on ebay and elsewhere for a used one if you are just going to "try" replacing it. Seems if you are already dissected down to it in the console, should be easy enuf to test your switch. And what do you mean by "console's computer" ?
