Old 05-02-2019, 10:57 AM   #3
PaulE
look in the owner's manual or search how to remove the headlight to change a bulb. Once the light unit is out you can see how to snap the old corner piece out and the new one in. There should be a tool for headlight removal in the tool roll in the back of the spare tire. If you don't have the tool, or even if you do, a 1/4 inch drive, 6 point 8mm (I think) deep socket with an extension and ratchet can make getting the light out a little easier sometimes. When you put the light back in, make sure all the tracks on the light unit are properly engaging and it may need just a little extra oomph to get it properly seated.
