Old 04-26-2019, 02:11 PM   #2
paulofto
2003 S, Arctic Silver, M6
paulofto's Avatar
Resurrecting an old thread.
I performed the roof relay hack as described using a relay I obtained from 'itsnotanova' The hack works as indicated allowing the roof to go up and down without the e-brake applied and rolling along. The one problem is the roof warning light on the dash stays on. Strangely, for the first few miles I drove the light was out then it blinked a few times and then stayed on.
I have my original relay and swapped it back. It operates as it should and the light goes out when the roof is up or down. I swapped the two relays a few times thinking a contact may not be seated fully but in each case the hacked relay did the same thing and the original operated as normal.
Has anyone else experienced something like this? I like what the hacked relay allows but not if the warning light is going to stay on.
Any help or suggestions are welcome.
