Old 04-25-2019, 05:34 AM   #2
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by elgyqc View Post
Thanks.
And for the center nut? Pelicans says 24 ft/lb (but it is not clear to me if that is for the original flange and center bolt or for the LN kit which has a stronger center bolt), elsewhere I saw 12 nm. Provisionally I torqued to about 15 ft/lb which seems about right as long as the original bolt is not too fragile.
IMS Solution manual says.
Center IMS flange nut torque must be at least 12 ft/ lb,but not to exceed 20 ft/lb
2003 Boxster S
