Old 04-25-2019, 03:34 AM   #10
truegearhead
truegearhead's Avatar
um, I think what tgh was saying was that if the car was running and moving, the engine drawing air would create that pressure so not a true test. you could do it on the other side when the fan wasn't running to get a truer test.
if you look at velocity maps of cars you'll see that the air is at a lower velocity in that area relative to other areas of the car. perhaps due to turbulence induced by the front wheel? anyways, if the air moves slower relatively then there will be more of it in that area so higher pressure relative to the rest of the car.
Exactly, if the engine is running it would be overcoming the vacuum. To properly test you’d have to test the fan side.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
