Old 04-24-2019, 07:42 PM   #1
The Radium King
The Radium King's Avatar
Originally Posted by Racer Boy View Post
No, JFP just told you that there is a slight positive pressure. It's very unlikely that any manufacturer in modern times would release an air intake design that hurts performance.
um, I think what tgh was saying was that if the car was running and moving, the engine drawing air would create that pressure so not a true test. you could do it on the other side when the fan wasn't running to get a truer test.
if you look at velocity maps of cars you'll see that the air is at a lower velocity in that area relative to other areas of the car. perhaps due to turbulence induced by the front wheel? anyways, if the air moves slower relatively then there will be more of it in that area so higher pressure relative to the rest of the car.
