Old 04-23-2019, 08:56 AM   #1
Burg Boxster
Originally Posted by Robert986 View Post
So, before I place the order IŽd would love to get your view..
-Is there any way to save the PC925?
-Is it reasonable to Think that the ATX30 will work?
The car is a combined DD/Track car, and I am aware of battery consumption, I never run stereo or such with the engine off.
Without know your duty/usage as a DD you might be able to get by BUT the juice probably ain't worth the squeeze as in you'll constantly need to keep on a maintainer. A lot is also dependent on what vampire electronics remaining in car. As a dedicated track car, which typically are kept on maintainers when not in use, then absolutely no problem as that's what these batteries are designed for... very low demand cycling.
You might be able to salvage the Odessey w/ a high quality maintainer like the C-Tek 7002 which has a recondition feature.
Good luck
"Cool Prius!"
- Nobody
