Old 04-22-2019, 08:03 PM   #1
Burg Boxster
Originally Posted by KRAM36 View Post
With this paint between the rotors and wheels, should that be enough to stop the galvanic corrosion? Recommendations to stop this galvanic corrosion?
Not likely to keep at bay especially b/c the wheel mating surface will likely wear thru paint and put the dissimilar materials in touch w/ each other again.
Painted or not... a little dab of anti-seize will help thwart or at least minimize... You know, just enough at each mating surface to get all in your hair, on your jeans and everything else you touch or think about touching for the next 8 hours. LOL
Note how there is no / very minimal corrosion on wheel or hub lip...anti-seize.
Regardless, nice mod and painting.
Good luck
"Cool Prius!"
- Nobody
