Old 04-22-2019, 01:41 PM   #10
KRAM36
Need For Speed
KRAM36's Avatar
Well I bought a SIR B90 Master Tool Kit. They are not cheap and it allows you to pull the bearings out of your car without having to take out the carrier assembly.
Also picked up a nice Pitman Arm/Tie Rod End Ball Joint Separator Remover Inner Bearing Race Puller kit.
It would be a heck of a deposit to cover the cost of the SIR B90 Master Tool Kit plus renting fee. Although much much cheaper then having a shop do it. The Pitman Arm/Tie Rod End Ball Joint Separator Remover Inner Bearing Race Puller kit wouldn't be too bad.
I was thinking about doing it locally as shipping cost is about $50 just on the SIR B90 Master Tool Kit.
2003 Boxster S
