Old 04-12-2019, 07:55 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
Originally Posted by 1096369fred View Post
I am thinking the easiest solution is to cut the red (Becker) connector off and replace it with solderess RCA clips/connectors and then I can plug directly into my Stereo? Will that be the ticket?
That should work, you will just need to make sure you correctly ID the left and right and + and -.
And if I am running the sound bar will my Alpine stereo be enough to push them?
Depends on the model of head unit. If it was me, I would probably run them off the amplifier.
