Old 04-11-2019, 05:08 PM   #1
Brian in Tucson
p1128 p1130 & p0300
My new (replaced last winter) engine is running like ****************--you can hear detonations inside the forward cats and it stumbles and sounds terrible. I have p0300, random misfires; P1128 & 1130 which is a problem with oxygen content.
I've replaced the AOS, and the engine isnt blowing white clouds, but the CEL's haven't changed. I have an new Bosch MAF on the way, is that what my problem is? Pretty sure I don't have vacuum lines leaking, the right intake might be leaking tho--one of the bolts going into the top of the head is stripped. (sigh) I know I've got to fix it, probably will put new one in with blue loctite to restore some sort of threads. Or Tap a the hole for a larger fastener.
2001 Boxster
2007 Toyota Highlander
