Old 04-09-2019, 04:15 PM   #443
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by KRAM36 View Post
Our engines don't work like that. Our engines pull air into it, that's the force acting upon the direction and travel path of the air. Pedro blows air into the Distribution T, which will hit the back of the Distribution T and the wedge would have a nice impact on the way the air travels. Our engines pull air in and it rides along the side of the Distribution T. That's why the Y shape is very important and having the wedge is not.
Holy Mother of God! I was chastised over this post and 1 1/2 years later the great Jake Raby says the same thing I did about the air being pulled along the short side radius. The Y shape is the most important part of the piece, even according to Jake Raby.
Originally Posted by Originally Posted by Flat6 Innovations
No, it doesn't.
The short side radius of the IPD is where the trick is. You can't develop an intake component using a shop vac. If you do, you'll never see that what you are doing is hurting performance, or doing absolutely nothing!
With a pitot tube inserted in the intake where the splitter is installed in this photo will give zero, or very, very little velocity on the flow bench. Why? Because the air is pulled to the short side radius.
Yes, I have direct experience with this.
https://rennlist.com/forums/996-forum/944002-alternative-to-ipd-plenum-2.html#post13767949
2003 Boxster S
