Old 04-07-2019, 06:08 PM   #4874
Newsguy
I tried to change the AOS. The mounting bolts must be original, because they are far tighter than a 6mm should be. I got the lower loose, but the top one is shrouded such that, one-handed, I can't keep good pressure on it with a ratchet and it slips off. I even tried applying pressure with a long screwdriver through the wheel well with no luck.
-H. L. Mencken
