Old 04-06-2019, 09:45 AM   #11
kiosko
Kiosko,
Yes, before you have brain surgery, try an aspirin..
Seriously if you replace the ignition components (plugs / coils) your engine should run much smoother, the plastic tubes and o-rings should take care of the oil leaks, and the timing is perfect to do them at the same time.
Afterwards, wash your engine and would be able to spot any other oil leaks (if any..)
Good luck
Finally got back to the car today. figure out #1 is the completely opposite of 6 where the oil leak is at (no oil on one). After feeling like an idiot, i swapped the coil in 1, nothing changes, engine runs super rough (feels like it only running on 5 cyl) raw fuel smell out of exhaust. did a compression test and make shift leak down test with weird results. a mechanic friend and i were stomped. 0 compression but pushing air into it, does not leak. see new thread today, i’ll try to link. Any ideas, i’m stumped.
Weird compression test results 2000 986 S
kiosko is offline   Reply With Quote
