Old 04-05-2019, 05:38 PM   #11
JFP in PA
Originally Posted by PaulE View Post
Plus a plain journal bearing needs a constant supply of pressure fed oil to keep the two metal surfaces separated by a thin film of oil, otherwise the bearing will fail immediately.
Jake actually tested what would happen if the oil feed failed by disconnecting and plugging the line, the answer after a prolonged period of running was “nothing”. Oil feed cools and prolongs the life of the plain bearings, but the splash oil mist seems to do a pretty good job in the short term.
