Old 04-03-2019, 12:09 PM   #1
Brian in Tucson
First of all, you should NEVER pressurize your braking system to 25 PSIG with the Motive tool, 12-15 PSIG is plenty. The plastic brake reservoir tank and seals were never designed to hold that kind of pressure.
Second, Stant makes an excellent coolant pressure testing system with all of the necessary adaptors to fit just about anything on the street.
This is one of those tasks that you're better off taking it to an indy shop. They have the proper tools and can put it up on a lift for inspection . The Stant kit is expensive and you won't work off the cost in a home garage. Euro shops will touch this task, other shops won't. They're afraid of elfen magic, I guess.
2001 Boxster
2007 Toyota Highlander
