Old 03-30-2019, 02:30 PM   #6
Ciao
Ciao's Avatar
Originally Posted by Markt213 View Post
Ok I will admit I am a very newbie!
I changed the oil/filter in my 05 Boxster S following the capacity levels in the manual.
It says 2.05 Gal or 7.75 Liters.
I put in 2 gal and my dash meter is showing completely full.
Do I need to try to drain some out or am I ok?
:confused
How long did you allow the oil to drain? was the P car level when the oil was drained?
Some let the oil drain overnite; others let it take an hour or so for a complete drain.
It is possible not all the oil drained, but if it did and you put in .05 less than the prescribed manual states you should be fine.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
