Old 03-29-2019, 11:59 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
With the door open, if the window does the short drop and rise when you lift and release the handle, the problem is most likely the micro-switch in the door latch. The best way to repair it is to replace the whole latch.
You can use a much less expensive latch from a similar VW/Audi, but it may need a slight modification to work.
Check out this thread:
VW do latch/actuator
