Old 03-28-2019, 03:09 PM   #11
JFP in PA
Originally Posted by BOOTLEG View Post
JFP,
As I prepare to put my EBAY engine in my car, I am trying to avoid the slippery slope of replacing things just because the engine is out of the car. So far, did IMS Solution, RMS, H2O pump, lo-temp TStat, DM flywheel, clutch & PPlate. I'd like to stop here but it's a 54K engine and has been sitting on my stand since 2015. Do I need to do the fuel injectors and AOS or are those easy to do later even with engine in the car?
I would at least do the AOS, which is out in the open now but won't be so when the engine is in the car, and it should also be easier to do the long hose that runs through the intake to the AOS. I would also consider doing the coolant tank (we only use the factory part) while the engine is out, again because it is simple now.
I would also look very closely at the oil fill tube and consider doing them for the same reason.
