Old 03-28-2019, 11:33 AM   #5
Lowski
Originally Posted by Txwhitaker View Post
Hi everyone! I’m new here and looking at getting my first Boxster. I found one near me, an 03 S with ~97,000 miles, with a couple of problems. The first and possibly the biggest is that it needs the coolant expansion tank replaced. Apparently it will start leaking once the car has been running for ~30 minutes, so it needs to be done immediately. Also it has thrown a P1328 engine code. The owner said it has come up in the past, but went away. The Porsche shop he uses said it might need a variocam solenoid replaced at some point. The independent Porsche shop quoted me $750 to replace the expansion tank, but I haven’t found out how much the variocam solenoid could potentially cost. With all that in mind, what do you guys think a fair price would be? Other than the above issue it’s in above average to excellent condition, garage kept, with complete service records. Thanks in advance!
$750 for a coolant tank replacement isn't outrageous. A OEM tank itself is around $350ish as you don't want the cheap versions. It takes time to gain access in the trunk, disconnect all the clamps blindly within the engine compartment and then reinstall. Then you need to think about a coolant drain and fill. If it has been leaking who knows how much water and what kind of coolant if any has been added. If the $750 includes the coolant drain and fill I would let the shop do it.
I'll let someone more experienced chime in on P1328 as I have no experience with it.
Lowski is offline   Reply With Quote
