Old 03-23-2019, 11:41 AM   #9
mgfranz
So my 2001 started doing similar things last weekend, looking for inputs.
If the door is closed, and you pull the door handle from the outside and the window does not go down, it's the door handle switch? What if it doesn't go down for either inside or outside?
If the door is closed, and you pull the handle and the window does go down, but immediately goes back up, it's the door latch mechanism?
mgfranz is offline   Reply With Quote
