Old 03-19-2019, 04:06 AM   #1
kk2002s
kk2002s's Avatar
Is there condensation on the truck lid above that area? (Looks like it from the pictures with moisture on the rubber seal)
That will also indicate issues with Cap/Purge valve/Tank.
Once you take off the plastic cover is there a white residue around your Purge valve? (This indicates it's leaking)
How is your coolant level?
Smoke from oil fill and dip stick, I don't know about that. Maybe after a longer drive, removing the cap maybe one might expect to see some vapor escaping.
Seal Grey
