Old 03-18-2019, 08:35 PM   #11
dghii
My .02...
Get a new top with a glass window. I'd go aftermarket glass window top as 03-04 tops are all old at this point (as mentioned above).
You can get an installer but this isn't a tough job and now special tools are required if you are a DYI'er.
Access to the top of the motor is a goofy reason not to get the aftermarket top. I accessed the top of my motor on an annual basis to take care of air filter, clean MAF and check PS fluid. If access is required for more extensive work, spend a half hour and remove the entire top and frame (30 minute job each way).
