Old 03-18-2019, 06:25 PM   #1
elgyqc
elgyqc's Avatar
If you gently feel around with a brochette skewer or something , can you feel the piece?
Yes I did that, I used a metal rod to more than gently explore the surface and the hole... it is solid.
Looks to me to be an "oil fouled spark plug saver" type of device. The intent was to have a central port (the hole you see) for the spark plug to fire through, but prevent oil scraped from the cylinder walls from reaching the plug.
That sounds like an explanation... I was thinking something like that, but more in terms of controlling the spark. If it is what you suggest is this common on Boxsters or Porsches and why only 1 cylinder?
Grant
