Old 03-18-2019, 03:30 PM   #3
barkinfool
barkinfool's Avatar
Just to add a bit more to rick's comment... On the drawing, #1 refers to the main drain from the plastic drain panels that sit under the convertible top. They get either clogged on either side, or the water drips down behind the seat because the foam plastic panel is ripped -- often as a result of the convertible top mechanism motor arms breaking and tearing holes in the foam. #2 are small drain holes along the front of the track edge of the rear convertible cover - harder to see, but you'll find them. I agree with Rick that it is most likely the water getting through from either of these two causes. Some have also reported water getting in through the driver's side door panel if someone removed the plastic sheeting in the door. Hope this is helpful & let us know if you get this issue solved.
Barkinfool
'02 Boxster S
barkinfool is offline   Reply With Quote
