				Broken support under seat
			My seat looked the same. Pulled it out and found foam was pushed out. Also broken plastic cross support holding electric plug. Fixed plastic with zip ties and tape. Yeh it’s funky. Found a hole on each side of metal sides so made flexible high strength plastic for added support and to keep foam in place. Still has worn look with stretched leather but am going to try a little heat to message and reshape. Doubtful it will help. When taking seat out make sure have female torx think it’s 10mm. Needed all my strength. The plug was a pain until figured there’s a slide out latch then pretty easy.
				__________________2002 Boxster S
 2002 BMW M5 Dinan stage 3
 2017 Honda Ridgeline
 2008 Toyota 4Runner
