Old 03-15-2019, 03:30 PM   #11
NewArt
Artist, 986S tinkerer
NewArt's Avatar
I’ve now pulled off all of the ancillary items from the block. Actually, it’s pretty obvious what should and what shouldn’t be reused. If you look inside the oil cooler, for instance, you can see that it is made up of a stack of waffles. Danger could be lurking in every corner! I will be replacing this part.
