The baffle helps to keep the oil around the pickup, it's a essentially a box around the pickup with hinges on the walls, so oil can move towards the pick up when cornering, but it can't move away from it (if that makes sense).
It's a relatively easy project to do. Lots of threads on it, if you use the search function you should get all the information you need.
