Old 03-13-2019, 11:52 PM   #10
Topless
Track rat
Topless's Avatar
Originally Posted by jaykay View Post
No down shifts ?
Careful downshifts.
Allow the oil to settle as long as possible when coming off a long left sweeper under braking. Downshift once only to select your corner exit gear and blip throttle only to 4k. Never ever blip to redline when the oil level is likely low in the pan due to G forces in the previous sweeper. The data on dead m96 engines suggests that the blip to redline under braking is when the oil pump cavitates, oil pressure drops to zero, and then takes out the engine, generally not the banking itself.
