Switched 12V in rear trunk
I had found the following by 'jsceash'...
"X59 Plug pin location 4 White plug next to ECU (left of ECU) Red wire blue stripe fairly heavy wire come from ignition relay and turns off about 30 seconds after ignition is off."
However don't know which is X59 connector and how to identify pin 4. Hence my request to post a pic with some brief info.
Thanks in advance!
Current Project: 2004 BoxsterEV - http://amsoneji.wix.com/boxsterev
