Hi All,
I did some search on the forum but could not come up with a good location.
Am looking for Switched 12V (switched on with the ignition key) locations to tap into in the rear trunk of my 2004 Boxster Base. Something I can use for powering the main contractor assembly for my conversion. Reasonable current capacity will be ok.
I don't have the service manual so if you are pointing me to a pin on a connector, I would appreciate the help in finding that exact connector. A pic would be ideal...
Appreciate the help in advance!
